Originally Posted by cbaber
I'm pumping my tires up to 60 PSI after work tonight. Thats a whopping 16 PSI over the tires indicated limit. (...) I'll continue to experiment with tire pressure in the real world, gathering my own data.
I'll watch that with interest. Think you can delete power steering, if you haven't done that already. Hope you do use top quality tires. Be careful not to overheat your pump.
(I'm at 48 PSI now... runs fine on that)
