Old 08-20-2013, 06:04 PM   #19 (permalink)
R.W.Dale
LE Camry - '03 toyota camry LE
90 day: 31.88 mpg (US)
I just an a couple tests.
No1 on the rear coil (run side) is firing on the mark with about 20 degrees of advance dialed in
On the wasted spark coil number 1 or 4 is also on the mark with the same advance dialed in
Now what I need to determine next is are the two #1's firing together or are they firing 180* out of phase
Too much junk to list. From a 10mpg caddy limo to a 5 speed Saturn
