Originally Posted by Spiffytexan
Thanks, guys!
What does this mean?
"Its a Chevy so you might want to extend or get a front air dam"
I don't know what this means...
The redline is either 4,000 or 5,000... I split the difference.
We use syn, no 4wd, what is a disco axle? Some nifty dance move that my generation thankfully missed out on? (I'm a Swing guy, myself.)
Thanks again, @ 1:33 am
Logan
Sorry, most 90s Chevy trucks I've seen have an air dam, 3" piece of plastic hanging down from the front bumper to divert air from flowing underneath the truck. Some trucks have them, some don't and it seem to help in the aerodynamics department.
Disco is Jeeper slang for disconnect. On older jeeps one of the front axle shafts was a two piece design with a sleeve. When you shift into 4WD the sleeve would slide over the two shafts connecting them, else in 2WD the shaft would be disconnected and nothing up front would be turning. Most trucks either have a similar system or hubs that you can lock or unlock. Wondering if you had one of those
