To start logging tanks in the Garage here on EcoModder, follow these steps:
1. Head over to your Garage by clicking the Garage link at the top
2. If you have a vehicle entered in the Garage, you will see several links including Delete, View, Edit, etc. Click on Fuel Log.
3. On the fuel log page, click on the link that says ADD another fuel log entry for this vehicle
In order for these to be accurate, make sure you top off your tank, preferably at the same gas pump at the same gas station each time. When you are around 1/8 of a tank, fill the tank and record the information on the page I showed you.
