Old 08-21-2013, 10:31 AM   #74 (permalink)
qx4dude
Originally Posted by cbaber View Post
I'm pumping my tires up to 60 PSI after work tonight. Thats a whopping 16 PSI over the tires indicated limit. My car will certainly vibrate to pieces, my tires will blow out, I'll wreck due to decreased traction, my fuel economy will get worse, and the center of my tires will wear unevenly. You can follow the progress in my project thread and when your theories are confirmed, feel free to post, "I told you so". Until that time, I'll continue to experiment with tire pressure in the real world, gathering my own data.
The cavalier attitude about exceeding "max sidewall" pressure is astounding. Teams of engineers at major tire manufacturers have worked with teams of engineers at auto makers to determine the maximum safe tire pressure - but we know better because someone on the Internet pumped his tires 30 PSI over the design specification of the tire. Clearly, a few of us put saving a few bucks on fuel ahead of the risk to ourselves, our families, and others on road. This isn't only about risking a blowout, or premature tire wear, it's about the affect that over-inflation has to driving dynamics, and the car's reduced ability to maneuver (or stop) in an emergency situation.
I'll admit that I have raised pressure in my tires 6 PSI over the door sticker's recommended 36 PSI (which has improved FE), but I won't go anywhere near the stated maximum 51 PSI sidewall pressure. I'll put my trust in the engineering team that designed the tire over an anonymous Internet user's "research".
The Following User Says Thank You to qx4dude For This Useful Post:
gone7 (08-22-2013)
