Originally Posted by Arragonis
Small update. Hermann's service included resetting the trip gauge (probably by accident) so I have no idea how good / bad this tank is. I can still use it to calibrate the SG2 (gallons used estimate vs real) but not to calculate overall MPG - damn.
So this tank cannot be used for MPG.
Do you have the odometer reading when you bought it, and did you record or reset the trip meter then?
In that case you should be able to work out the current distance on this tank...
I like spritmonitor.de because it requires you to fill in the odometer readings and works out the per tank distance from that.
![](https://images.spritmonitor.de/544051_25.png) lifetime FE over 0.2 Gigameter or 0.13 Megamile.
![](https://ecomodder.com/forum/fe-graphs/sig7127a.png)
