Old 08-22-2013, 09:24 PM   #7 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.42 mpg (US)
Way back when, I built a sailing dinghy out of 1/4" fir plywood. Standard lumber yard plywood, not marine grade. Painted it inside and out with a good coat of primer, followed by a topcoat of enamel. All surfaces were fully coated, no gaps or thin spots.
That boat was stored outside upside down on blocks when not in use. I sold it after nine years. The plywood was perfect - no weather checking. Some of the bottom paint was wearing thin and starting to expose the primer.
I believe that plywood checking is caused by wet/dry cycling. If all surfaces, including hidden surfaces, are sealed, then the wood maintains a constant moisture content. Constant moisture equals zero expansion/contraction, so no checking.
The Following User Says Thank You to JRMichler For This Useful Post:
Cd (08-22-2013)
