Old 08-23-2013, 11:26 AM   #9 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
you can also use bending plywood. Normal ply has the grain of each sheet rotated 90 degrees for strength. This makes bending a bit difficult.
Bending ply is designed to bend. The veneers are all laid with the grain in the same direction. You can get either 4x8, or 8x4 depending on which way you wish to bend it.
Columbia Forest Products : Radius Bending Plywood
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
Cd (08-23-2013)
