Old 08-23-2013, 11:44 AM   #122 (permalink)
niky
Again, designing a suspension to deal with high pressures is expensive. And to a point, futile. BMW have yet to design a car that rides comfortably on run-flats, which are just as stiff as tires at 50 psi, for the most part.
Toyota can't even design a suspension for the Yaris that doesn't bounce horribly with "stock" low-profile tires at 35 psi.
Originally Posted by qx4dude View Post
I believe extremes are usually dangerous. It's like going to the doctor, and getting a prescription for blood pressure pills. The bottle says take one tablet twice daily - USE AS DIRECTED.
Doctors and pharmacists went to school for at 8 years (and longer) to be able to practice, and dispense medicine. Most high blood pressure patients will heed the warning label. Others will do their own "experimenting" with the dosage.
Well, coming from a family of doctors...
Dosage for most "over-the-counter" medicine and prescription medicine is basically ballpark guesstimation. If one patient is one hundred pounds and another is two hundred pounds, the amount of medicine required to ensure efficacy naturally varies. And the amount of medicine that would be considered an "overdose" varies, also.
"Recommended dosage" is set a certain number of milligrams to ensure that both the one hundred pound "adult" patient and a two hundred pound "adult" patient both get a big enough dose for the desired effect, and that a ninety pound weakling will not die from an OD. The doctor can prescribe a much, much higher dosage in special cases... not fun being on a massive cocktail of antibiotics (at three to four times regular dosage) if you've got a particularly nasty bug... since antibiotics are downright toxic...
Then again... as CapriRacer keeps pointing out, the "maximum pressure" on the sidewall does not connote OD. It's basically the recommended dosage required for a certain desired effect. And the desired effect isn't "not blowing up."
In a perfect world, doctors will take your weight and BMI, then do some complex spreadsheet calculations before giving you a prescription. In real life, they'll prescribe the same dosage they prescribe to most of their patients. One which is safely above the minimum effective dosage for most average-sized humans and well below toxic dosage.
Originally Posted by ACEV View Post
To Everyone:
Please note that this topic is not about under-inflation. It is only about over-inflation. Let's not confuse the issue any longer by mentioning somethng that is clearly off-topic and non-applicable.
It's applicable because my "normal" inflation pressure on my truck is 26 psi. Anything that tests pressures over that is applicable, in my case.
The NHTSA tells me 26 psi is verboten for highway driving (which is why I ignore it completely), while my "full load" inflation is 45-50 psi, which is over the "maximum sidewall" on most tires that fit.
As CapriRacer has pointed out, said number has nothing to do with durability testing on the tire.
