Originally Posted by doviatt
Remember you had to hold it into the initial stall after you set your trim.
It is important to note the plane will be naturally seeking the 65 you trimmed it at. It will only stall again if it has so much speed and energy that it exceeds the stall angle while trying to maintain the 65. Oscillations would be expected to reduce until the stability has returned.
I would be interested in the stall and stability characteristics of this Synergy plane and so would the designers. I cant wait to see the proto fly and hear about its performance.
It does pitch up enough on the first one to stall, or at least an abrupt drop through. After that it "falling leafs" to a stable condition after successive smaller oscillations.
You can see how the diesel engine is doing in other airframes. That is the exciting part for me, the diesel. I got my hopes up when Zoche was in development and testing, only to have it all evaporate.
I kept seeing a pair of those 300 HP beauties on the wings of the 310.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
