Old 08-23-2013, 04:20 PM   #7 (permalink)
trekmandude
yes, I was concerned about motor current. I can only mention what the battery current was because that is where my sensors are. next test drive I will hook up a motor voltage gauge....
the BMS will not allow a discharge greater than 400A (batt current).
could the motor current be greater than double the battery current? 3X? 4X? I'm just wondering where to set the current limit on the Revolt....and if there is something obvious that I've missed. well, obvious to someone else at least.
