Originally Posted by HyperMileQC
-Engine loading (LOD)
-Throttle position sensor (TPS)
-Water temperature (°cWT)
-12v Battery voltage (VLT) / Engine RPM / Intake air temperature (°cIA)
I wish TPS and LOD had decimals...
You probably could get them to display decimals via xgauge, I know someone did on a different forum with these value :
ISO/VPW
Throttle Position (XX.X%)
TXD: 686AF10111
RXF: 044185110000
RXD: 2808
MTH: 00C800330000
NAM: TP
It steps in 0.4% increment due to hardware limitation (255 discrete steps)
Maybe you could get it to work!
