Old 08-26-2013, 12:33 AM   #21 (permalink)
GreenHornet
GreenHornet's Avatar
Hey gang,
Well I purchased a 1977 12 seat Dodge Sportsman the other day. You could say it was an impulse buy. We have been talking about getting a larger vehicle for years and I finally decided the time was right. The van had been sitting in a barn for over 12 years. It was a single owner van with only 56K miles on the drivetrain. I got it for $750 which is not bad considering the Dana 60 rear end can often fetch a higher price than that!
So after a solid hour playing with the carb my friend and I got the fuel up the lines and into the engine. Once we got it there the engine idled as if it was new off the lot. We opened up the valve cover to peer into the engine and much to our astonishment the engine was cleaner than just about any used engine we had ever seen.
So now that I got this 4,600lb beast what the heck am I gonna do with it?
Although this is not my ideal RV candidate it would make a solid family hauler for extended road trips. I have a good sized family and we often go camping so in this sense it makes for a great vehicle for my family needs. I did a little research and did come across several Sportsman RV converts so the RV possibility is there if desired. However the more I look at it the more I envision something completely different.
I tend to think the Sportsman makes a much better candidate for a modern streamliner than an RV! The thought of creating a modern streamliner with the ability to seat 12 comfortably is quite enticing to say the least.
The first modifications will most likely be an engine and transmission swap.
The stock engine is a 360 V8 with an A-727 3 speed transmission. This combo with the Dana 60 rear end nets a combined 12mpg!
If it was you what would be your engine and transmission swap choice for the Sportsman?
GH :-)
