The overall final drive (3.15) works out to the theoretical top speed of 83 MPH. Peak torque at 2500 RPM will be 55-60 MPH in 5th gear. First gear at max (3600) RPM works out to right at 22-24 MPH, according to my calculations.
At max power the fuel consumption is .5 GPH (180 grams per shaft HP per hour=about 33-34% efficiency). At peak torque it's probably 60% of that amount, so if I can get peak torque to sustain 55 MPH the mileage should be pushing 200MPG if it will maintain 55 MPH at 60% of peak consumption.
Double that if electric, and no need for a speed controller, with the hydraulic setup.
regards
Mech
