Old 08-28-2013, 11:45 AM   #4 (permalink)
jtbwatson
The Blazer - '00 Chevy Blazer LT
90 day: 16.31 mpg (US)
Originally Posted by dlb View Post
is it 2wd or 4wd? how long has this been going on for? has it stayed the same since it started or gradually gotten worse?
tires were the first thing i thought of but it sounds like you covered those. if there are CVs, i would inspect those next. look for obvious damage like tears in the boots. then i would check all the wheel bearings. jack up each corner and spin the wheel, listening for growling, clunking, etc. while the you have wheel up, push/pull on it to check for play.
good luck.
It's 2wd. Just recently started about 3 weeks ago and it has stayed pretty consistent actually. There are no CV joints, but I haven't thought about wheel bearings yet. That'll be my project for today.
