I've been checking the Timer2 perishes not be related to the INT0 and INT1, but with the PWM pins OC1A and OC2B.
If I understand correctly, the Timer2, control the Pins 3 and 11, but as PWM output.
Please correct me if I'm wrong.
Originally Posted by t vago
Sounds like you have set yourself up to be able to simplify your LCD output routines.
Apparently this was the easiest part, the idea was to release the PWM pins for possible upgrades, while staying with the PWM pins free, for play with one or the other to make the injectors work.
Thank you
José Rodrigues
