Old 06-26-2008, 11:12 PM   #185 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
I am prob going to do what metroschultz says with the jacking points I just have to wait and get a few scraps of metal to do them with so they will probably be done after the car show one day when I have nothing better to do but for now I am making good progress finishing up the car.
Side skirts make it look much better.
And now that the last of the bracing and crap is done I can put the belly pan on.
I will get the front done tomorrow then put the car back on the ground to seal up the wheel wells. I plan on just opening the rear wells into the duct so the air can flow out the back bumper from the tires. The belly pan is 1/4 inch away from the tire so it should act as a scraper to keep a lot of air from being pumped around the tire. It will be reinforced with aluminum to keep it holding up better near the tires.
I also need to at least double how many screws are holding it in place I am just putting enough in the coroplast to hold it more or less where it needs to be but once I get it right I will put them every 10 or so inches.
