Old 08-29-2013, 08:06 PM   #34 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
It's been a while since i last popped in for any updates, looks beast! lovin the fiesta comparison too! wish I had the hatchback , great tanks on it as well...
Will look fantastic when its on the road!
Anxious to see how the seating/peddle/steering layout will be. Guessing that you have left the nose as a crumple zone?
I'm gonna guess your integrate lights as best you can?
Maybe a bit overkill, but are you gonna add a cross sectional tube to the frame behind the seats? A side collision(hopefully never) doesn't look like there is much of "margin" compliance if hit at a higher speed..
If not, What kind of thickness tubing are you using for the frame? as a basis for my own project (eventually)...
Also have you looked into Formed Plastic if your budget allows for body work (here and there)?
staying tuned! (better this time)
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
