Old 08-30-2013, 01:09 PM   #16 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by josemapiro View Post
I've been checking the Timer2 perishes not be related to the INT0 and INT1, but with the PWM pins OC1A and OC2B.
If I understand correctly, the Timer2, control the Pins 3 and 9, but as PWM output.
Not sure if you mean "pins 3 and 9" on your AtMega2560. On the AtMega328 (and presumably earlier chips), brightness is mapped to Port B bit 1, which is pin 15; and contrast is mapped to Port D bit 6, which is pin 12.
