+10 on the e-fan upgrade - and it is an upgrade. The fan hardly actually needs to run to cool the engine at all when you're at speed. Don't forget to wire it in using a thermo-switch. If you have a rad that has the auto trans ports on it, plug one side, fill the tube with coolant/water mix and put the thermoswitch in the other side. Saves on having to mod things.
