Old 08-30-2013, 04:46 PM   #5 (permalink)
Sven7
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Seems odd to buy a classic truck and then put LRR tires on it and stuff. Anyway, I got good results from a lawn edging air dam on my 352ci F100, if only for the highway trip, after which I removed it for aesthetics. It was surely a lot less work than underbody panels. Larger OD tires will help on the highway, though if you're doing much city driving that might cancel itself out.
Pull the passenger mirror off, and the driver's side if you're comfortable with that legally and safety-wise. You could also simply swap out for smaller mirrors. If there's a way to remove the wheel arch extensions and get flush-fitting wheels/tires, I'd do that too. Get some Moon-style wheel covers, or make some. Ultimately you might want to swap in a smaller engine if you really want low 20's MPG. A 4cyl diesel would be perfect.
For the fuel log, go up to the top of the page, click on "Garage" and add your vehicle. There will be a self-explanatory fuel log entry area there. You can see the results underneath your avatar on the left.
