Old 08-30-2013, 06:30 PM   #49 (permalink)
IamIan
IamIan's Avatar
E96h (96% ethanol with 4% water) is 100% renewable, while E85 still uses some gasoline.
Agreed ... but ... Makes no difference to the point that was being made.
The ability for a vehicle to run on a Bio-Fuel as an option is not exclusive to the old 7,700 lbs vehicle ... the newer vehicle can also be made or modified to run on a 100% renewable bio-fuel ... but the newer Prius like vehicle will produce less tail pipe pollution per gallon and use less gallons per mile while doing so.
So from a pollution stand point ... it still is = Con for old.
And , as you pointed out yourself , the 'gasoline' be it 100% or even the % in E85 can itself still be a 100% renewable Bio-Fuel.
Originally Posted by cRiPpLe_rOoStEr
Any source of organic matter can be turned into bio-fuel, including some sort of synthetic gasoline like the one that was made out of wood chips in Poland during WWII.
