Old 08-30-2013, 08:11 PM   #19 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by 4862forestgrove View Post
Thanks for the input... could you take a quick look at the attached drawing of the treatment of the front radius and tell me which your intuition favors... I believe there are equally easy to build. Thanks in advance. BB
Don't make the front of the trailer into a scoop that scoops air between the towing vehicle and the trailer.
Use a convex shape.
Don't use any circular shapes at the rear.
They'll destabilise the trailer.
Cut it off sharply at the rear, if possible with the sides / top / bottom plates extending a bit (2-4 inches) beyond the rear wall - i.e. forming a shallow box of thin plates around the tail end.
If you get around to covering the gap, the covers can rest on / slide over the convex front of the trailer.
The Following User Says Thank You to euromodder For This Useful Post:
4862forestgrove (08-30-2013)
