The rear suspension with the car sitting normally is not in the way of the coroplast but if I jack it up there is enough give to it so it won't tear it off the car when the suspension is at full drop. I am thinking of putting a split in it at the suspension arm and some rubber material I have just in case it gets stiffer as it ages. The rubber would give it enough flexibility that it should work fine for pretty much anything I might do driving.
For right now though I will just leave it alone and see how it does. It is going to be fun sealing up the front wheel wells I bet so that is what I will be working on mostly tomorrow.
