Originally Posted by jyanof
... I see the pictures previously posted of your controller design in this post. The power section does not appear to be similar to the original Revolt design.
Good luck in your efforts!
Thank you for your information...60 C degree ambient temperature it is very impressive that controller still work well.
Yes you have absolutly right previous design is not mine, but I have come back to original design and even, improved it. I am worry for safety now during the tests driving, so why I want to have put lower temperature parametrs before I get trimed my controller. This time on road I will be driving with temperature indicator to see what are normal values, then I set up proper thermal cut off.
