Old 09-01-2013, 08:16 PM   #12 (permalink)
gone-ot
...beats walking...
IMHO, the "clutch" function should be a pressure-sensitive switch *IN* the manual transmission shifter handle: As you squeeze the handle, it disengages the electric clutch so you can shove the shifter lever into the next gear...and it then re-engages the electric clutch as you release pressure on the shifter handle.
