Originally Posted by Allch Chcar
What most of the Ethanol supporters have found is that the only way to get past the problem is to minimize the amount of Gasoline if not completely eliminate it.
What a farcical fantasy! Gasoline engines, designed & built to burn 100% gasoline, perform best burning 100% gasoline. The problem with 10% ethanol blends is that ethanol isn't burning efficiently in gasoline engines.
Yeah, ethanol supporters seldom (if ever) have long years(decade?) of records, comparing 100% gasoline & ethanol, showing the worthlessness of ethanol when burned in gasoline engines, designed & built to burn 100% gasoline.
Ethanol supporters need to experience true, but more expensive, ethanol engines(INDY cars) that burn 100% ethanol at its most efficient, to see the major differences between gasoline engines & ethanol engines. Tinkering around with two different fuels(ethanol & gasoline) in the same engine isn't making it.
