Originally Posted by BamZipPow
Been doing some research on single wheel trailers (there's a few of them) and found that this sort of setup might work fer you. It might make fer a longer swing out but it might be something you may want to consider. Would it be possible to adapt this tech to yer trailer?
Swivelwheel 78...
The extra swing out would be limited - and certainly a lot less than a regular trailer - as the swivelwheel trailer can be made quite narrow at the end .
