Old 09-03-2013, 03:35 PM   #25 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
I like auxiliary transmissions, personally. In a 5&4 setup, you get something like 20 nominal ranges, but there are overlaps, and if you know your input/output ratios and what the engine /wants/ versus what you want, you can do some funny things with it... for instance, in one of the old trucks we had, you might split between 3/2 and 3/3 by shifting to 2/5 or 1/5. It takes a bit of practice and understanding of the ratios to do things like that, though.
I really love multi-speed transmissions. The loss in forward momentum can be solved with dual clutch gearboxes though. Ask VW about that.
