Old 09-04-2013, 08:38 AM   #12 (permalink)
justme1969
justme1969's Avatar
First 2 attempts have failed. perhaps a morerichened formula that I can start with a blow torch will work. Here at factory the forklift tires leave solid trails of expended rubber on floors. if I can compress it or bond it into steel wool then heat up tube with a hand torch it may give solid results that will last 3-5 minutes? I havent given up just rethinking the solution.
I need to get it soon because Im about tired of driving the undieing POS ready for A/C and clean carpets cushie seats etc.
