Old 09-04-2013, 01:49 PM   #55 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
The 250cc Honda rebel will also have a much higher CD, although having less A probably... so you might come up about even on that. Difference being that the rebel is geared lower and builds torque much higher in the RPM range than the diesel does, so your setup being closer to 1:1 should actually be marginally more efficient in terms of driveline.
