Originally Posted by rmay635703
Something else to note, (although more expensive per WTHR) is that for motorcycles BB30's and NiMH Hybrid battery packs can be used instead. These can be had for a couple hundred per complete pack (if you look/wait) but weigh more, are high voltage but also can last longer and can be easier to charge.
This is the first I've seen NiMH suggested for a motorcycle. Do you have any online vendors you'd recommend I check out? Also, are these the smaller packs like you'd find Lipo packs?
