Old 09-05-2013, 02:15 PM   #67 (permalink)
user removed
Va. motorcycle tags are 7X4 inches. I plan to incorporate the stop, park and turn signal lamps in a pod that surrounds the license plate, in the very rear of the vehicle.
The plan is to name it R.I.D.E. The initials stand for the company name which is Regenerative Infinite Drive Engineering. Would like to get a tag with the initials, not sure if they allow 8 Digits for the periods.
I need to check with the state for minimum width specifications for the signal lights. If more than 12 inches then I might move them forward in separate pods, aero of course.
The rear view mirror will be a single unit, convex wide angle, placed between the two gullwing door hinges on the roof. A single mirror is required so I will go that route (no camera) to avoid inspection issues.
regards
Mech
The Following 2 Users Say Thank You to user removed For This Useful Post:
aerohead (09-05-2013), mikeyjd (09-05-2013)
