Also thinking of being able to revert a stored EEPROM parameter or screen setting to the "factory" hard-coded default, via keypress.
I put this at the top of loadParams():**
Code:
if (RightButton)
buttonState = buttonsUp;
return 1; // don't load parms from eeprom; use default compiled parms
There's a similar check for LeftButton, to reset the saved tank data in the eeprom. The "prompt" for these hidden key features is the "MPGuino" startup screen, which gives you a 1.5 second delay to press (and hold) the key.
** i later removed the option, out of paranoia that i would accidentally clear my settings
