Old 09-05-2013, 04:51 PM   #47 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by nickdigger View Post
Also, you should assign a higher version number (1.00tav? 0.98tav?) It certainly is a full step above and beyond the base. 0.86 might mislead someone to think that flashing your code would be plug-and-play. At a minimum, the stored params will be corrupted.
Yah - probably should change the version #. 1.86tav!
Interesting. My stored parameters go away each and every single time I reprogram my MPGuino. I had assumed this would happen for anyone. Maybe not, hm?
Probably should also change the guinosig byte to something else, especially because the code does change the number (and size) of stored parameters based on what features are compiled in.
