Old 09-05-2013, 09:24 PM   #11 (permalink)
IamIan
IamIan's Avatar
Originally Posted by rmay635703 View Post
If you have a scangage and disconnect the battery you can definitely clear the cel for a while.
Also a grid charge isn't THAT hard to do.
Gen-1 Insight IMA code is even easier to clear ... no scanguage needed ... disconnect the 12V battery for 1 minute ... it forgets it had a IMA code ... it will also forget the IMA SoC ... but if you let it idle for a few minutes it will figure the SoC out again.
