Old 09-06-2013, 06:04 AM   #48 (permalink)
josemapiro
First of all, thank you for his work that fantastic, I have not tried using it on my board, but will test soon as I can.
Originally Posted by t vago View Post
Actually, I did a little Excel thought experiment last night, playing with a simulation of 4 buttons using varying resistances. It turns out that it is certainly possible to read 16 different values, and Chrysler actually used to do that with the cruise control buttons. However, how would resistor tolerances be addressed, as resistances change with temperature? Or is this even a concern?
If you succeed it to work the buttons optimal, before I tried several options, and when he had to press more than one button at the same time, I always had some failed, for the value to be very near each other, but maybe I have only tried with the combinations that did not work, when I should have worn that worked. LOL
Thank you
José Rodrigues
