Originally Posted by majorrich
Getting ready to go pick it up. Got the title and ready to learn. It has 138k on it and most everything works, kinda sorta. It leaks fuel, but the PO says it's a rubber hose that slips on the injector ala VW Beetle fuel line. Apparently they go bad occasionally. I'll be looking for a more permanent solution to that problem. Of course having sat for so long, it takes a mighty leg press to stop it. Personally I am excited to learn a whole different technology. Then if the Zombies attack, they can't steal my distributor cap!
Yes, the first objective of Zombie Armageddon will be stealing all distributor caps. It is known.
I hope that you are able to come up with a good solution for the fuel lines!
