Old 09-06-2013, 09:06 PM   #9 (permalink)
cRiPpLe_rOoStEr
Originally Posted by majorrich View Post
It leaks fuel, but the PO says it's a rubber hose that slips on the injector ala VW Beetle fuel line. Apparently they go bad occasionally. I'll be looking for a more permanent solution to that problem.
I'd recommend you to replace that rubber hose for some different material better rated to handle biodiesel and veg oil.
