Old 09-07-2013, 07:27 PM   #1 (permalink)
Eco_Bob
Smile Buying a Civic VX?
Greetings All!
I am debating between going with a 92-95 Civic VX and a Gen 1 (preferably 2003-2005) Insight.
Right now I think I am leaning more toward the VX mostly because it will be lower cost upfront (avg 2-3K vs 3.5k-6k for an Insight) and easier to maintain/more options to find places that can work on them. It also seems that total cost of maintenance will be lower on the VX than the Insight over the course of usage
The MPG will not be as good (I estimate I will spend roughly $250 more in gas per year over a MT insight), it doesn't look nearly as cool as the Insight and can't use odbII gauges (scangauge, etc) ...I guess I could live with that :-/ The only real downside is finding one that hasn't been horrible molested and hasn't seen snow/salted roads?
With that being said it seems finding a VX nearby me that hasn't been in an accident or has had major performance modifications that significant impact on mpg is rare...
However I found these two potential candidates - can I ask your opinions about these?
Candidate 1 - asking $3,600
1995 CLEAN TITTLE 222000 MILES
HID LIGHTS 6000K
NEW LOWER SUSPENSION COIL OVERS
VX MODEL GREAT IN GAS HARD TO FIND
ENGINE RUNS GREAT / NO LEAKS
A/C BLOWS COLD
SONY BLUETOOTH
95 HONDA CIVIC HATCHBACK VX, BLUE/GRAY INTERIOR ORIGINAL ITALIAN MOMO SEATS
EXCELLENT CONDITION,COMPLETE,MANUAL STICK
SPORT COMPLETE STAINLESS STEEL EXHAUST SYSTEM,
13" RIMS OEM WHEELS
ALARM SYSTEM AVITAL TWO WAYS(POWER LOOKS OPENERS)
MUGEN LIP, MOMO SITS EMBLEM
NEW PAINT GRAY AND BLACK ROOF WITH CARBOR FIBER TRIM
NEW TIRES
RECENTLY TUNE UP
ALL MAINTENANCE ENGINE AND TRANSMISSION BY HONDA DEALER NEW SPARK PLUGS WITH WIRES NEW DISTRIBUTOR, ON AND ON ..MANY OF NEW PARTS REPLACED ..LOOKS GREAT ..AND DRIVES AWESOME. I SPEND A LOT OF MONEY IN THE CAR.
I DON'T REALLY WANT TO SELL IT, BUT I JUST BOUGHT A LARGER CAR FOR MY FAMILY.
Candidate #2 - Asking $2,500 (This one is kinda far...2 hours north of me I think)
I am selling my 1992 Honda Civic VX. I have put a lot of new stuff on this car. It has about 60K on the D15B motor (from Japan) that was installed about 6 months ago. I still have the original D15Z1 motor that will be included with the sale if you want it. The original VX tranny works fine and has new fluid. I am going to try to remember all that is done to this car in a list below. It is a AC car and it does work but on 95 degree days it get down to about 52 degrees, so I am including the compressor that came with the motor from Japan. The windows work and are tinted 20% in the front and 5% everywhere else. It has Acura Integra GSR black leather seats in front but will also include the original VX seats. No cracks or tears in the dash or door panels. This is a very clean VX for a 92 with close to 200K on the body. The speedometer did not work when I got the car so I put one in that had higher miles. The body is around 190K but the odometer say 228K, it is close though. This car still gets 50+ mpg when driven calmly; I have gotten 53 mpg many times on a full tank with the current engine and had 62 mpg with the original motor. This car only has an 8 gallon fuel tank from the factory and it will go as far as my 2013 Taurus with 17 gallons. If you are looking for a vehicle to Hypermile with, look no further, I am sure you can get 70+ mpg. If you don’t believe me then Google it and you will see. Better MPG then most hybrids for a fraction of the cost.
Some of the new stuff on it:
D15B JDM engine installed, not a hack job, look at the pics
Competition stage 4 clutch kit, about 4K miles on it
New axels
New cooling system including silicone hoses (last forever), aluminum radiator, new fan, thermostat. Temp stays at about the ¼ mark on the hottest of days in the worst traffic.
Complete rear brakes about 8K on it, shoes, hardware, wheel cylinders, and drums
New master cylinder, slave cylinder and fluids along with new ceramic front pads about 4K miles on it
New tune-up including plugs, wires, cap, rotor
New 4 wire O2 sensor
New muffler is about 1 ½ years old
Various sensors were replaced in the last year including TPS, IAC
New alternator and battery about a year ago
ALL fluids have been changed in the last year
Tires are a matching set of Sumitomo on the original super light and rare VX wheels and have about 70% tread left
I am sure I am forgetting some stuff but this car is very well maintained. I would not hesitate to take a road trip anywhere in this car. Everything is so cheap and easy to replace, so why not fix it.
Some of the aftermarket things I have done to make it a little more interesting to drive:
Short throw shifter, will include the original
HID 8K headlights, can put in stock bulbs if you want, no wires were cut
Traction bar, strut tower brace, lower chassis brace were installed in the front to help the body roll that these cars have. Stock suspension still functions great.
Here are some of the things I had to modify in order to install the current motor:
The ECU was swapped for a stock P28, I do not have the original VX ECU
The above mentioned 4 wire o2 sensor
It is a V-Tec motor and it’s all there but this ECU is not V-Tec compatible but no check engine light is on and for MPG you will not notice it anyway.
The body condition:
It does not appear to have been in an accident. All paint is evenly faded except for the hood which I replaced with a new Keystone replacement and painted in my garage, not perfect but it the same color. There is a dime sized rust spot on the roof by the water channel and a small amount by the rear fender wells and that’s about it. There are some dents here and there but overall in good shape. See pics for the locations of them.
The hood is lifted in the rear because of hood spacers. They help reduce the underhood temperatures. The power inverter will NOT be included in this sale. Also I will be available to show the car by appointment only.
Of the two which would be a better choice? Better to wait and find one in better condition or maybe an Insight? I would like to get another 125K miles out of these without too much maintenance/possible repair work if possible...
Any guidance on what to look for when shopping for a used VX would be greatly appreciated!
Thanks again!,
Bob
