Old 09-08-2013, 01:27 PM   #8 (permalink)
Flakbadger
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
Originally Posted by RdRnr View Post
Thanks. I usually run them at high 30s cuz I like a firmer ride. Max pressure is 44, I'll try 42.
More PSI is better for MPG, but too much can be an uncomfortable ride--I run my Ecopia tires at sidewall max, but found with my previous crappy tires that low 40s was still way-y-y too rough. I did it anyway 'cause I'm insane.
How exactly do these help? I'm guessing it's better to smoothly guide air around the car than let it flow under where the aerodynamics are really bad?
Bingo. The grille block also keeps excess air from going through the torture chamber known as your engine compartment.
Welcome to the forums, by the way.
~Matt
Current Car: 2023 Chevy Bolt EV
Retired Car: White Lightning
Retired Car: Betty White
