Old 09-08-2013, 04:17 PM   #96 (permalink)
HypermilerAX
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
I finally cut the wheel covers down to the rim diameter +15 mm (vs +28 mm).
I removed my 2 mirrors and put 2 white plastic panels, I will work on inside mirrors.
I finished the wheel skirts. Some tape before and after to make the airflow as smooth as possible.
I will have to bore a hole into the covers because now if I wanted to check air pressure I would have to remove the whole skirt and cover.
ID:	13735   Click image for larger version
ID:	13736   Click image for larger version
ID:	13737   Click image for larger version
ID:	13738   Click image for larger version
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
