Old 09-08-2013, 04:34 PM   #10 (permalink)
RdRnr
RdRnr's Avatar
BabyTaco - '14 Toyota Tacoma base
Originally Posted by Flakbadger View Post
More PSI is better for MPG, but too much can be an uncomfortable ride--I run my Ecopia tires at sidewall max, but found with my previous crappy tires that low 40s was still way-y-y too rough. I did it anyway 'cause I'm insane.
Bingo. The grille block also keeps excess air from going through the torture chamber known as your engine compartment.
Welcome to the forums, by the way.
~Matt
OK, I'm now at 42 psi. I'm guessing I'll have to check more often being at a higher pressure?
Aerodynamic torture chamber? I'm looking at my F-150 grill. I'm also looking at a roll of 2" clear packing tape. It would be really easy to tape off some sections. Maybe when it starts to cool off . . .
