Old 09-09-2013, 10:31 AM   #23 (permalink)
Daox
Another month, another batch of cool projects to take a look at.
1) DIY 9.2kw Solar Array
Pinballlooking has put together a very nice 9.2 kW solar array. Check it ot.
DIY 9.2kw solar array - EcoRenovator
2) Hot Water Heater Timer Options
Pirate is looking for a hot water heater timer. He gets a list of options on what can be used.
Looking for water heater timer - EcoRenovator
3) Rheem HP50RH Water Heater Review
Hikerjohnson goes over the installation and then reviews his new Rheem HP50RH heat pump water heater.
Review: Rheem HP50RH Water Heater - EcoRenovator
4) Attic Heat Project Designed From The Bottom Up
Exeric has designed a great heating system that utilizes hot attic air to help heat his home.
Attic heat project designed from the bottom up - EcoRenovator
5) Solar Swing Set
Ever find yourself in need of a ground mount for your PV panel? Why not use your kid's swing set? That is what BenNelson is doing.
Solar Swing-Set - EcoRenovator
