Originally Posted by slownugly
Lza09 is the correct sensor. As long as the sensor has that code on it you will be good.
I'ld be SO relieved if I don't have to buy another one!
The question is how can I match up the colours I've got with the colours of the original on the wiring diagram? Is the order they're in in the plug, match the other side of the plug? I'm wiring everything into the CX wiring harness, to the P07 ECU, I know I'll be "hard" wiring some things, like EGR, (and controls), VTEC, 02 sensor. My brain hurts!
