Do you have a 5 wire harness plug for the harness side? The cx has a 1 wire oxygen sensor wire so I'd just hard wire it like the egr and vtec. But you can't chop the plug up on the sensor side because there is a resister in there.
The wires on one side of the harness might not match the wires on the other side. That's normal.
Burn lean and prosper \\ //
