owly -- It's novel to see people advocating for rear-steer, so I have some questions, if you don't mind. - Do you have a cite-able reference one could point to in discussions of the subject?
- What was the top speed of the truck/loader?
Me too. Except I think the downfall was aerodynamic lift on the lee side of the nose in crosswinds.
It seems testable with a recumbent tricycle. If the rear wheel rotated fore-and-aft on a pin at the top of the fork; and there existed two plates, one on the frame and one on the fork, that had 10 holes in an arc on one plate and 9 holes on the other—then the inclination could be adjusted to 1/10th the hole spacing. For test purposes.
If rear steer were applied to this vehicle, the result would be 3-wheel steering.
I haven't checked back through the thread but I believe I suggested turning the top torsion bar into anti-roll, that would shift the spring/roll ratio considerably.
Interesting idea on using the top torsion bar as an anti-roll bar. I know the suspension is not compressing to any significant degree with the stock torsion bar setup. I assume you are talking about disabling-removing the center anchor for the torsion bar itself?
Thanks to everyone else for suggestions-support!
regards
Mech
