Old 09-10-2013, 05:37 AM   #50 (permalink)
Tesla
The Truck - '02 Nissan GU Patrol ST
That link talks about the engineering problems to overcome, my question is specifically:
Is there an aero benefit to a rear mounted radiator?
Egineering effective solutions is a stage 2 problem.
For the issues in the link, one could use a secondary cooling system, leaving engine cooling system as is, just adding in a heat exchanger under bonnet to transfer heat to secondary system at rear, if rear system fails, engine system is not affected.
