a point to consider is that operating a gasoline engine closer to peak torque rpm at certain loads improves bsfc. l question the mpg predictions. 111 mpg at 55 mph seems optimistic.
better aero, along with good door seals, eliminates wind noise. lrr tires make less noise. and a large enough muffler quiets the ice. the high number of ratios in new transmissions are actually meant to keep engine rpm low for low noise and vibration - not much to do with fuel economy. running at peak torque - for best efficiency - negates the extra gears. engine noise will dominate at 100 mph. unless you get a torquey diesel that operates at 1300 rpm.
the 112 bhp opel eco speedster got 113 mpg at 140 mph!
“Soft shapes follow us through life. Nature does not make angles. Hips and bellies and breasts — all the best designers have to do with erotic shapes and fluidity of form.” - Luigi Colani
