Old 09-12-2013, 05:34 AM   #1 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
Idle - RPM increase
If you have a Manual Transmission, shift into neutral and the RPMs increase (i.e. from 700 to 1100) - what is the likely cause?
Vehicle motion causing more air entry and therefore raising the required RPM or...
The car moving giving a signal that it needs to maintain a higher idle for some reason?
The testing I've done suggest that as the car slows, the RPMs drop back down - but above say 40 or so, the RPMs rise as if there is some reason to maintain a higher RPM.
